Old 26th February 2009, 12:46 PM
Originally Posted by Zip View Post
Wouldn't mind moving to 275 profile on mine, but would b*gger the speedo and odo readings.
Zip
Not really Zip. 245/45-18 is the standard tyre for A and S8 although 17, 18 and 20s were offered.
To remain within 1% of the 245/45-18 circumfrence you could use
275/40-18, 275/35-19 or 275/30-20. However, the minimum recommeded tyre width for 275mm tyres is 9" and will fit rims up to 10.5". If the ET remains the same as you have now then it would have the effect of adding 15mm spacers to your existing setup and the tyre extending 15mm further in towards the suspension. The other point is that Audipages (see Sticky in Wheels and Tyres) reckons that over 265mm fender mods will be required. This would be almost certain if your lowered beyond that of stock S8.
