Helicoiling is basically putting a tube with a thread on the outside and a thread on the inside to replce the knackerd thread. It means removing metal so that the inner thread is the same size. If I were doing it I would have the head off. There may be ways the a pro would do it with the head on. Be interesting to see. Sorry to hear about that.
Have you tried threading a good plug back into no 6? It may be that the plugs thread is Fubared and the head is ok. If you can get a plug in and torqued down then there is no need to helicoil.
Mike
