  #46
Old 9th February 2011, 11:10 AM
ok:
1) The RNS-D tuner wont work with the RNS-E, you need an RNS-E specific tuner.
2) If you already have an RNS-E, and it has the TV working to a fashion, then its a safe bet that the tuner was changed. This is a good thing, as its a very different wiring loom and would take some effort to run it to the back of the car.
3) The RNS-E digital hybrid tuner is a straight swop for the RNS-E analogue one, the cables are identical for the power/can etc, although the hoods around the aerial connections might be slightly different. The hoods come off though and the SMB's plug straight in. I change my D2 between digital and analogue tuners quite a few times
4) You would have had a type B tuner on a 2002 car, but I cant believe that it still working, so you must have something different in there now.
As they say, a picture speaks a thousand words, post up what you have and I'll try and help
