Old 26th March 2011, 10:19 PM
RanjS8 RanjS8 is offline
Default further to the above
The washer level sensor has nothing to do with the washer pumps....
Further if your wheel was buckled you would definitely no about it.....you would get shaking in the steering wheel above a certain speed.....kind a like when the wheels are not balanced properly......if you are not getting those symptoms then you will be fine with what you have.....for the sake of sanity however....just rebalance the wheel and move it to the back and dont worry about it......
