Faulty mafs and lambdas at worst would make it run lumpy, or cause the engine warning light to come on. I cant see it would cause the issues you describe....
I would suspect the immobiliser if it was purely a starting issue, but it sounds like it died whilst running fine ?, which would rule it out.
If both fuels produce similar results, you can rule out fuel supply, which leaves really coils / plugs / timing / wiring
Is it smooth when it runs for a second or two, or a bit lumpy ?
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
