Old 27th April 2011, 02:35 PM
s2_bo s2_bo is offline
Im presuming fuel should flow in at the pipe which does not have the FPR attached to it?
If i crack the FPR one off its dry....
Also when cracking off the other fuel line it spits as the nut is undone, so there must be air in the fuel rails.
Maybe my fuel gauge is lying, (says its half full) and when i cranked it over to check fuel pressure it was only spitting out.....
Anyway, i have sent someone out to get 30l of 98ron so ill see what happens hen that goes in.
I think its poss that a cold start on gas can be unsuccessful as the liquid gas can freeze the vaporizer..
If all the above are right then thats hopefully the only problem...
Will update later if i get it to work.
Thanks again for your time..
Bo
