Old 27th April 2011, 08:01 PM
The system is complex! I've played around in the tank when replacing a fuel pump.
The pump sits in a sump of fuel and it is above the level of fuel at less than a quarter of a tank. However, fuel remains in the sump-part of the pump assembly which allows the pump to prime. When in operation the pump drives fuel into the tank to either side to drive 2 turbines that send fuel to the fuel rail. That way each side is being fed fuel so they stay the same level
With me so far?
The low pressure return from the fuel rail goes up to the header tank at the fuel cap and cascades back down into the sump that primes the pump.
If the sump dries out then the pump wont prime. Simples!
