Thread: Scuttle Drain
Old 6th May 2011, 05:24 PM
Well, it wasn't raining.
Stripped the interior for de-moistening and cleared the pair of evaporator drains on the tranny tunnel. Mucho water came out. These looked OK but plainly were not. Anyway I was able to blow through them with a bit of hose attached so they ought to be ok now. They were definately blocked before.
Also cleared both engine compartment drains. These were also clogged but I poked wire up from the arch. Their entry points are cunningly hidden.
No luck with the cowl drain though. After ages of farting about, the best result was a fastish drip from both sides of the drain. This later slowed to a slow drip. I shoved every thing (ok, almost everything) that I could wedge in, in and wiggled it about but no real result. The thing will be choked with these damn holly berries.
Any other ideas?
