Your right on the engine. 100k is not big mileage at all if it's been serviced properly. I have heard of several over 250K and one with over 400K on it. The timing belt must be done every 80k and it must have had the proper oil.
The transmission though can be a different story. Audi do not service the transmission as they claim it is sealed for life. Remember, life to Audi is until the warranty runs out. If the box is silky smooth and less than 100k you may wish to leave well alone until it shows signs of trouble then do a filter and fluid change. If it's less than 80k you could well benefit from a regular service of filter and fluid every 20k. Over 125k is when they generally start to fail if they are going to. We have a number of examples on here of big mileage boxes, but I think they are the exception.
Personally if I had a high milage transmission I would start a service routine and if it percipitated a transmission fail by disturbing something then I would pay for a rebuild from a reputable transmission specilist and get the guarantees that go with it. These cars are good value and if your handy with a spanner, reasonable for the level of comfort and performance to run.
