The Audi tuners are pretty robust, and and you can see they support many different country signals....
The rolling you see would normally indicate the source (xbox) is chucking out a 60hz signal, where on a PAL setting, the TV tuner would expect 50hz, which can create the roll...
When you set it to NTSC, this is a 60hz standard, so it stabilises, but because NTSC and PAL use a different colour system, you lose colour. Black and white is a standard system worldwide, which is why black and white always works, its a mismatch of colour systems that loses the colour....
I'd guess the TV tuner needs to be set to PAL uk, as it was on default, and the Xbox needs to be throwing out 50hz only.... If you're still in doubt, try another source like an ipod, dvd, etc, but the Audi TV tuners are pretty good, they should take almost anything 'sensible' as an input...
60hz pal isn't sensible :-)
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
