Old 9th March 2009, 08:23 PM
Those boxes should sort it as they transcode the 60hz tv signal down to a 50hz one.
Yes.. M$ did kind of screw up a bit, but most tellies will do 60Hz PAL, but obviously it's aimed at Hi-Def.
In fact.... try setting it to hi-def, but choose a lower resolution and try the green pin.. see what happens (if not green, then one of the other two)
