Thread: Lpg?
Old 19th May 2011, 08:17 AM
Thanks for input, which given you're running the same block and electronics as most of us, is quite valid.
I had exactly the same with LPG, a regular route and knew where to get the fuel so all was well. Filled up at the top of the M1 to get there, and filled up at the bottom of the M1 to get home. Easy.
One slight difference between the D2 A8 and the C5 A6 is that you could have chosen a diesel, these guys cannot. Audi UK in their wisdom only brought petrol varients into the UK, so if you want to drive an A8 pre 2004, you get petrol. Hence why LPG is so prominent amongst A8 owners.
The fact that you had a choice to get diesel, and went for an S6 anyway makes you probably an even bigger petrolhead...
I cant comment professionally on the remaps, but I think with LPG its more complicated as you can only have 1 map, but you have 2 fuels, requiring 2 'optimal' settings. If you optimise it say for economy on LPG, then it might be pants on petrol.... Maybe Ben or Mike will comment.
