Old 6th June 2011, 08:46 PM
Remember that unless they have one of the special machines that cycles the new ATF into the box as it drains the old ATF there is quite a bit left in. Draining only leaves 2 to 3 liters in the TC and valve bodies. Not changing the filters is a false economy as the filters filter! Therefore it will slowly clog up. Did you ask for an ATF and filter change? If so then back to the garage I would say. If only a fluid change was requested then you have probably got what you asked for.
Given the colour of the ATF now only analysis of it would detect if it was the wrong fluid.
