View Single Post
Old 16th June 2011, 07:37 PM
yes that will be great im thinking of starting with an eaton m12 or something similar and running about 5-6 psi boost on standard compression ratio and then when its all up and running maybe think about some plates and upping the boost, im still not sure if id be better off with a centrifugal type charger and mount it where the abs module is and have piping run round through the standard intake but finding a fair priced one is hard second hand
