I had it running on a PF car, so its do-able, but its a right PITA.
heated seat wiring changes slightly, fog lights change completely and require an external latching box as PF ones latch, and FL are momentary - Hazard warning light changes, but most of the Audio wiring is simple changeover. Heated rear window moves to climate module too, but thats a fairly simple wire move
Biggest problem as ever is the A/C module, which whilst its fundamentally the same wiring, the FL module uses a can signal to know if the engine is running to switch on the A/C compressor - No Can on PF, so no A/C without some other clever stuff. On My S8 I had a can signal generator to put the speed signals on the bus for the climate, but seriously, its a lot of messing about for little gain....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
