For information the cowling around the viscous fan has a diameter of approx 16". However the core of the radiator doesn't start until approx 2.5" below the top of the cowl. Therefore when you are getting an electric fan that has to sit flush with the core so that it sucks air through the core you'll need a smaller fan.
I bought a 13" fan and had to cut away a portion of the lower cowl to allow the fan and mounting lugs to fit flush with the cowl.
There for I reckon the largest fan you will get away with is about 11" going by the Kenlow dimensions here. They don't have an 11" fan so 10" is probably the one to go for.
