Thread: Brake discs
Old 17th July 2011, 08:14 AM
Just a note on pads and disks. The EBC Yellow pads are good. I have seen a set in Bembo calipers get burnt black from heavy track use and still be fine for the drive home. Personally I would always go for a set of Ferodo DS2500. They have excellent cold bite, good wear and low noise, if a bit dusty.
As for disks I don't rate the EBC disks much, they tend to be noisy and the cross drilled ones are just that 'drilled' and there is a risk of cracking under heavy use. If you want drilled disks go for the ones that are cast with their holes like the Brembos etc.
It may sound odd, but a good combination is EBC yellow pads and standard disks. A better combination is the DS2500 and standard disks. For me a set of DS2500 and AP Racing vaned disks are the best if you are happy to pay for top notch brakes.
