Old 4th August 2011, 10:23 AM
SilverS8 SilverS8 is offline
i only just went from std to S8 coilovers with a 20mm drop and that has mad a hell of a difference, would like to make the S8 set up slightly more stiff maybe 20% more and then poly bush about 85% of the car has any one poly bushed yet ?
I can live with the S8 suspension but a bit stiffer as you say. So i am wanting to try out the Bilstein B6 Sport shocks. Some say on Audiwolrd that they are alot stiffer but some also say that Bilstein Sprint is a stiff shock and after having Bilstein Sprint on my S6 for several years i must disagree.. they give a very nice ride comfort and are excelent for track and so on, but they are as far from stiff as you can get...
It annoys me that Koni doesnt supply adjustable shocks when for instance the KW2 kit has adjustable front and rear...
Could probably fit Konis from a A6 or S4 B5.... same suspension but more weight...
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
