  #48
Old 9th August 2011, 11:04 AM
Having digested, I'm thinking all symptoms could be down to the CL system. I'm sure the radio key is fine, and I imagine the indicators were winking away like a disco to prove the point.... ?
On FL cars it has two outputs -
1) Does the drivers door and fuel flap
2) Does the other doors and boot
Its so that you can enable the secure 'double unlock' feature so central locking only opens the drivers door on one blip, and the rest on two. Stops people jumping in your passenger seat to mug you when open the car coming back from the shops etc.
If you have a leak in one pipe, and you have single unlocking enabled, maybe the leak in one pipe, would cause a loss of pressure across both. Thus, unplugging one pipe and plugging up the hole (with a finger I imagine) would send pressure down the one working pipe and would work.
The boot is 100% mechanical I think, no deadocks, where on facelift, you have deadlocks on the doors, so once locked with air, the key will not unlock it no matter how much you mess with it.
Sounds like a simple (but annoying) case of leaky air line.....
