thanks
i got hold of the same diagram off elsa win earlier and removed it and checked everything last night. when reinstalling the pump when i had issues with it earlier this year (ended up being the tracker disabling the pump) i forced it a bit too much seperating the pump from the housing.so corrected it and made sure seals are ok and everything is seated ok.
drove it to work this morning on 2nd white bar from red so looking good.if it still has issues thinking of changing the sender unit as elsa says replace it if the top seperates from the base when removing the pump which mine has done.
im not sure how much fuel it had in it when it cut out, i never checked.if it does it again will check hope it doesnt.
