You can hope!!
If it was me... I would remove your battery and locate the ECM in the boot. Then test the wiring (Use the colours) and do a continuity test from the caliper to the main wiring loom to the ECU. Rule that out first.
Easy to do with a paperclip and an electrical testing meter.
