View Single Post
Old 15th September 2011, 12:24 PM
Nollywood's Avatar
Brilliant. So 5-speed tip is longer than 6-speed 01E, hence the tip propshaft needs to be lengthened.
Tozo also modified the D2 subframe, by adding extra platforms, to accept B5 S4 tranny mounts. If using D2 tranny mounts, subframe won't require any modification. Same frame for tip and manual, the rubber mounts are also the same, and accept D2 01E mounts.
So far, so good.
