  #30
Old 27th September 2011, 11:41 AM
Nollywood's Avatar
thanks for the help i will buy some of them then they are 6000k not sure about lumins but hopefully will be brighter maybe get some uprated halogens to go with them as the main beam more than likely needs doing as well
If I may ask, why would you want to fit 6000k HID capsules? When 4300k ones give out the greater lumen output? There's a reason OEM HID set-up in production cars is 4300k - because it's the best, output-wise.
Unless you just want your lights more blue-ish?
