Old 1st October 2011, 10:40 AM
Sump plug washer is a 'one time use' part. It squashes when you torque it with 50nm. If you try to reuse it chances are you can get leak. I'm almost certain you'll get leak if you reuse sump plug washer.
Hence you need new filter (which comes with rubber seal for filter housing) AND new sump plug washer.
