Hi took the boot roof trim off today and it looks like the bolts you are referring to are only accessible from under the parcel shelf. Mine are bolted into spot welded metal retaining fixings with the bolt heads almost touching the underside of the parcel shelf.
I'm assuming the correct way to remove these is to remove the parcel shelf first? can anyone please confirm?
Many thanks
James
