Thread: Bought An A6
Old 4th October 2011, 05:42 PM
Originally Posted by Mick View Post
it is a little high at the moment.
The S6 with 18" Avus Wheels had a lower profile tyre than the 8 which doesnt help.
I am planning on lowering springs which will drop it 40mm and when the tyres need changing I'll put lower profile ones on.
Is it standard suspension or sports you have. I have X reg 2.5 TDI Quattro with sports suspension and I find it too low. Fancy a swap on suspension if yours is standard? Max axle loads are 1200kg for rear axle on both cars and front is 1205 on mine and 1260 on yours not sure if that is not too much of a difference. Anyway that's just a thought as you are a bit far away and postage both ways would be a bit expensive.
If you change it for aftermarket coilovers I might be interested in your if they are standard and cheap enough.
