Hi All.
Currently figuring out what parts I require to do the same thing. Replace the fixed motorola bluetooth with a non-rSAP factory bluetooth module.
Just not clear on what is required as far as the connectors are concerned. Would probably be clearer when I have everything laid out in front of me, unfortunately we don't have an Audi dealer nearby to order the required connector from so I need to do it in advance.
Where I am confused.
The motorola module has a 42-pin connector
I assume the new module has a 54-pin connector.
What is this 36-pin connector mentioned earlier? Is it some adapter that was included in the car of the OP and I don't need to worry about it?
I'll most likely be ordering a reversing camera retrofit kit from Kufatec so might try to order this 54-pin connector also. (just the connector, not the BT kit)
Would it be the 8K0 051 592 mentioned earlier, from what I have seen, that is a harness for the AMI, prob has the 54-pin attached also. Can the 54-pin be ordered by itself?
Sorry for all the questions. Just want to get it right and not have to be waiting for further parts down the track.
Also, are any changes required within VAGCOM to let the car know the motorola is gone and replaced by the standard BT kit?
