Although it's a 54-pin on the unit itself, there was only a 36-pin connector in the plug, sounds crazy, but the other pins aren't used anyway.
Car regonises the unit straight away, but you may need to go in with VCDS and let it know it's a BT kit rather than the Motorola.
