On paper, the W12 is the one to have as a luxury weekend barge. Most are long wheel base, without sports suspension or sports seats and are built for wafting along. I would have had one in an instant, until recently.
If you want sporty, the S8 is the better choice by far.
For running costs though, the 4.2 is probably the one to have, simply because you can not only get second hand parts for it, but you can actually fit them easily.
The W12 seems such a tight squeeze, if anything goes wrong under the bonnet, its an engine out job, which I'm astounded to say was a job a local Audi garage wouldnt quote for, as its so rare and specilist requiring specialist jigs, that they didnt own. Cats are the big failing, at nearly £1K a piece, and with 4 of them, 5/6 years old seems to be the time they're all going. At £5K + for the engine out to replace them, theres no wonder you're seeing W12 prices falling. Im sure people with friendly MOT stations have fudged it through the test, but do you want to buy into that hassle with your hard earned dough?
Considering the one I went to look at was about as tasty as you could hope for, and I still walked away at £7500, you can see my complete reluctance to get involved with the things.
Shame really...
If you are looking at one, take vagcom with you and check the engine ECU's - both of them - for errors. Problems with the cats will be logged in there. After a while the engine management light comes on. Take the car for a good test drive, then run vagcom to make sure it hasnt been freshly reset just before you arrived - The one I test drove had, and the guy was really reluctant to let me Vagcom it. He knew the game was up as soon as I mentioned plugging in......
Ideally, you want a W12 that has recently had all 4 cats replaced by Audi with supporting paperwork, which will be virtually impossible to find cheap, otherwise budget the cost of a D2 gearbox times at least 2 for repairs.
W12 gearbox isnt without issues either, but thats the least of its problems
On the plus side, its chain driven, so no cambelt to change, thank chuff for that. Just 12 spark plugs and a shed load of oil then....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
