Old 20th October 2011, 10:06 PM
If it's a combo of the tranny tunnel and scuttle drains being blocked, you'll actually SEE the water slosh from the left side of the tranny tunnel. You can see it happen if you're taking a right hand corner.
Also, sometimes water will actually slosh out the centre consoles rear air vents and land in the rear passenger footwells.
Is this your trouble?
If not, it might be something else.
Have you done that big old 'invisible' drain 'ole in the centre of the scuttle?
