Old 6th November 2011, 09:21 PM
You will need to have the facelift instrument cluster coded to the car I'm quite sure, you should have gone for an S8 one as you get the white dials too and they look much better then an A8 one. Get a £10 GPS receiver from eBay and throw it behind the satnav somewhere, works fine. Worst case scenario as I understand it if the canbus doesn't work then the unit won't switch off when you pull the key out or light up when you put the lights on, it won't display sat nav instructions on a D2 with or without canbus anyway, just track names. Your going to have to make it work now you've cut it to size. It looks good in there. Speak to Ben Wardle at Shark Performance about coding, he's a top guy.
