Well, I can't say for sure, but based on the research I've done for my S8 I'd say they should be.
They will presumably be a bit smaller so the speedo will overread.
My standard tyre is 245/45R18 on an 8J wheel, those are about 3% smaller.
(I've gone for 225/55R17 7.5J winters which are almost exactly the same diameter as 245/45R18)
The offset is a few mm less then the standard wheels so they will sit slightly further out, but as they're narrower the outer face will be in almost exactly the same place.
What wheels/tyres do you have on now and what design/origin are these?
