Old 6th December 2011, 09:50 AM
You have 1996 car right?
1.Connect to dash in VCDS
2. Select adaption
3.Use channels
5- oil change service, in 1000km, normally 15 for 15 000km
6- distance till inspection service 1, enter as above but normally 30 for 30k km
7 - time in x10 days till inspection service 1, normally 36 for 360 days
8 - time for inspection service 2 in days x10, normally 73 for 730 days
The value in those channels will show distance/time remaining. Enter new value, test and save. This will be less then values above if service was done a while ago so enter appropriate value to as much distance/time remaining.
Please note that distance used is in km not miles in all cars so do not forget to convert values before entering.
