I finally got my contacts information to upload from my phone to the rns e.
On my iphone i am using the latest software version 5.0.1....
The codes i used for the rnse were as follows
Module 77 0011522
001xxxx D3/C6 High System
00x1xxx Standard Steering Wheel
00xx5xx K line Diagnostics
00xxx2x English Uk Voice Control
00xxxx2 English Uk DIS information
Then use adjust the following adaptation channels as needed
128 Base Volume
129 Time Bluetooth stays on after ignition off
131 Microphone sensitivity
133 BT Activate/Deactivate
134 Handfree via bluetooth or phone cradle
135 Bluetooth Pin
Module 37 0309753
03xxxxx Audi a4
0x0xxxx Diagnostic for front speaker active
0xx9xxx Bose Soundsystem
0xxx7xx Mobile phone prep self diagnostic able with comfort operation
0xxxx5x Aux Input
0xxxxx3 CD Changer Only
More detailed explanation of the above codes and the adaptation channels can be found in the following link.....
https://docs.google.com/viewer?a=v&p...NmMyOGQyZjYwYQ
I am now very happy and hopefully this will make it easier for others with similar problems...
