Old 27th January 2012, 08:15 AM
Nollywood's Avatar
I have no idea how it works. I used it 3 times, with a LANDI LPG system fitted. The first time the doughnut-style tank was out, as I was buying a slightly smaller one, but all the pipework was in place. The other two times, the tank was in place, though empty.
And before anyone asks, I did declare it, nothing was hidden.
Interesting reads around, you may wish to take a look at this:
Nice lady will ask you if you “have an LPG tank”. That is the most stupid thing I’ve ever heard – so what if I have an extra tank for petrol? How can they find that it’s an LPG tank and what if it left from old LPG installation?
Why they did this restriction? People are afraid of LPG or any king of gas. Dont know why but I've met many who claim to rather have just electric supply than gas. Eurotunnel has bankrupt once and there was an idea to close it permanently (no profit). Because of lack of money, safety systems weren’t improved and there was an incident few years ago and as they didn’t have enough money to improve it they had to find a witch and burn it on the Pyle. This way the “did” something to improve safety.
Main idea is that LPG is heavier than air and will stay at the bottom of the channel. There is also higher (much higher) pressure at the lowest point of the tunnel so they assumed that it might affect some lpg installations to start leaking. Although it’s very easy to put few sensors around to check if everything is ok. There is a ventilation system and how much the LPG can leak within 30 minutes trip? If anyone’s car is leaking then it’s very easy to check it when entering the tunnel.
I know few people which passed eurotunnel with LPG but their cars weren’t registered in UK so they couldn’t check if the car has an LPG.
If you will go on ferry, you may find big sign to cut your LPG off. Year, right, there is no way to do it as it cuts off automatically…
Culled from http://www.omegaowners.com/forum/YaB...=1201210159/20
