Old 29th January 2012, 08:26 PM
Aux hot water pump. It is used for the resting heater and fails with remarkable success. It will create an awful bearing-like scratching sound like your engine just ate a spark plug.
It lives under the passenger side of the air intake.
I think I've documented it on here before.
It will spin up a second or so after putting the ignition on, and stays on.
The real test is to run the resting heater, which will also put it on. That should be pretty conclusive.
Not too expensive, couple of hours to change as its easiest done from the passenger side of the bulkhead with the glovebox etc removed.
A8parts are well aware of the fault and should have a replacement handy
