Old 21st January 2009, 07:02 PM
Default Interior Trim Repair Sticky
Here we will post links to Interior Trim related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about you 8.
INTERIOR
Broken Arm rest Solution - Audipages
Replacing Rear Seatbelt - General Git
Wet Carpets - Audipages
Wet Carpets 2 - Botang's Hole - Botang on Tyresmoke
Removing water from rear center air vents without dismantling - daviesbike
Replacing Clicking Climate Motor - IT
Cleaning Sunroof Water Drain Hoses - Elsaweb - Architex_mA8tey
D2 PF Rear Parcel Shelf Removal - Norretal
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
