Old 9th February 2012, 06:09 PM
I suggest you get a copy of ElsaWin. Most of the wiring diagrams are in there but they are very fragmented. There is not like single engine wiring diagram with everything on it. If you need something specific I can try to find it and export to pdf.
I believe it has crank position sender and the same signal is used also to determine speed.
Are you going to run stock ECU or aftermarket solution?
