Old 9th February 2012, 07:11 PM
47p2's Avatar
47p2 47p2 is offline
Oh and also im about to tackle the Audi with a rotary polisher and some P3000 tomorrow any advice ? my car was resprayed and im not totally happy there are flat spots on the car where there is almost like thousands of dimples and its dull rather than shiny in some places almost like the clear coat was not the same thickness in some areas ? if you have some advice for that or would prefer to pm me then that would be a great help as you have done a fantastic job on all of yours
Go very carefully with the P3000. A basin of warm water and a few, just about 6 drops of Fairy Liquid or similar and soak the P3000 for 10 minutes before using. I like to rub two pieces of wet and dry together to remove the coarse initial cut as I find it too severe when starting with a fresh piece. Do not lean heavy on the paintwork, use a rubber rubbing block if you have one, rub in straight lines, keep the P3000 very wet and don't let it dry out. Go gently and keep checking, if you rub through the clear coat the only cure is to respray. Don't try and take all the dimples out or you will go through the clear coat, you want to reduce them but leave them almost invisible. Also if you remove them completely when you polish up you will see a wavy finish to the paint as there is nothing to hide the rubbing marks.
Post up some before and after pictures and let us know how you get on.
Best of luck
Nite Blue 3.0L SE Quattro
