Thread: central locking
View Single Post
Old 23rd February 2012, 05:57 AM
Curtis's Avatar
Curtis Curtis is offline
ok i got it fixed but its a really weird one im not too sure how it fixed the problem.the boot lock mechanisim is faulty so if i lock the doors u will hear the boot lock sucking air for while then stop.i think this caused the problem because i looked at the wiring diagrams on elsa and the fuse 1 in brown holder goes to the left door so i had a look around but i was a bit lazy to remove the door panel and it was late and i remember after locking the doors while driving it wasnt working when i got out the car.according to the diragram the central locking fuse goes to left door lock actuator and microswitch for the alarm and interior lights.now my left door microswitch is broken and only works if u manually move the switch.when i moved the switch heard the pump run and stop and when i replaced the switch all working.
so im thinking that the pump somehow got stuck and was drawing current and until i messed with the switch in door it didnt stop.maybe im wrong but its working. need to replace that boot lock and door lock.
thanks for the help
