Old 29th February 2012, 05:51 AM
>> running idle it sounds like a diesel engine
Camshaft chain tension is maintained by oil pressure in our engines AFAIK.
If oil pressure is not that strong enough at idling, then chain starts to rattle. When RPM goes above idle, the oil pressure becomes strong enough to tension chain properly. Change oil pump and problem should disappear.
