Originally Posted by A8 Doc
I have never changed a Audi V8 engine so take this into consideration BUT:
One all the engines I have swapped behind the flywheel there is a rubber seal that goes over the crank and holds the oil in the engine. Prob about a fiver, but a perfect time to swap. Will take half hour to do properly but saves an annoying oil leak all over your torque convertor in the future?
These little suckers have Sealing Flange (Fnar Fnar) see part #32
The actual seal is not available as a spare and the flange is 131 euros on Vagcat!  And I have to go through 2 other gaskets to get to it.....
It will probably be coming of when I strip down the old lump to asses the damage so I'll know then.
