Old 12th March 2012, 04:58 AM
AusA8 AusA8 is offline
What is SSP & WOT???
Statutory Sick Pay
As quoted previously and by ainarssems, WOT is wide open throttle and the SSP is the self study program that Audi issues to all of its tech's as part of their training.
The problem is that variable manifold flap shafts become stiff and seize because of corrosion. Replacing arms with stronger ones could result in something else braking like shaft. Best solution would be to free the shafts, lubricate with anti-corrosion grease and replace plastic arms.
Whilst I agree with you, the plastic shafts and flaps are not the issue, it's the build up on them - especially the carbon build for FSI engines. Sometimes the bearing on the manifold are to blame also. They are easy to clean up, but pulling apart the assembly and reinstalling is not an easy task as there is a 'blind' fitting at the rear that can cause all sorts of issues if it's not placed correctly and I note that Audi Aust won't clean them either! From my point of view, the movement was not restricted, hence the linkage simply failed.
A8 4.2 S
