Old 17th March 2012, 06:29 PM
well im thinking that if i can track the coding that it uses when the button in the boot is activated and use it against the coding that is used when the button is pressed in the car then i may be able to trick it into thinking that when you press the button in the car it actually thinks that you have used the key fob remote to open the boot and thus double pressing it again will close it ?
