Thread: Wheel advice
View Single Post
Old 18th March 2012, 09:43 PM
47p2's Avatar
47p2 47p2 is offline
Originally Posted by Glync View Post
Hi all
Will these fit an A8
I realise they are a different offset from the standard but ...... they do look tidy ..
From a late model A4 RS
8.5J X 19 H2 ET48
PART NO:4F 0 601 025 BA
Cheers Glyn
Would it be these wheels? If so they will fit the D3 no problem
Just need to check they are strong enough to take the weight of a D3 (The weight should be stamped on them)
Current Wheel Specs
Width 9" Offset 44 mm (This is the spec of the 5 spoke wheels I had on my car)
New Wheel Specs
Width 8.5" Offset 48mm
Results
Inner clearance 2mm more (This means the wheel is 2mm further away from the suspension on the inside)
Outer position 10mm further in (This means your wheel will sit in 10mm on the outside edge)
Nite Blue 3.0L SE Quattro
