Old 22nd March 2012, 01:45 PM
I fitted Philips X-treme Vision +100% bulbs to my high beam assist and front fogs - you can actually tell when the lights are on now in the dark whereas the old ones made no difference whatsoever to the light output!!
Originally Posted by mannyo View Post
2) it supplements the main beam when in use, although most of the main beam light is xenon.
Any H7 bulb should the bill as a replacement.
Thanks for the help guys. It is all becoming as clear as, well, xenon! I shall probably look at some improved output halogen H7s. Iceblue8 is right - its often dark and wet up here and you need every bit of help you can get.
I did check the xenons and they are D2R.
