Old 26th March 2012, 12:00 PM
Get them from your local main dealer - surprisingly cheap and generally decent quality. I ended up replacing all of mine as they were all different brightness!
The inner ones have the same fitting (it's offset so make sure it goes in the right way round!) as the outers BUT they need a narrow glass bowl so if they give you a traditional bulb shaped one it won't fit through the hole when you try putting it back in!
Fittings are easy enough - just twist to release
