I'm not keen on the led look unless you can change every bulb - since there's been some recent discussion on the centre brake light I guess that can be done too. I don't like it if there's a time lag difference between bulbs - it looks odd IMHO
Not sure why 1 wouldn't work unless there's an underlying wiring fault. Do you have 12v available when the light should be on? Sounds like you'll need to trace the fault back if not
