Before you rush to strip half the interior, check out the B pillars...
The facelifts are famous for the B pillar black strip on the outside rubbing at the top.
Because its an outside noise that is tranmitted inside through the metal its tough to spot.
You can remove the top part of the drivers B pillar interior to reveal 2 10mm bolts that hold it on to the outside. Remove it, and go for a drive.. Its worth doing first as the roof lining will require all the grab handles, a,b,c&d trims, reading lights, all 3 sun visors, sunroof controls and sunroof tray trims removing.... and, there not really anything up there to squeak to be honest.
Once you've removed that lot, it will come down from the front and push it back towards the rear of the car to disengage it from some hooks that hold it to the rear. If you pull down at the rear you *will* break the lining clips that hold it...
Yes, thats experience speaking
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
