Old 16th April 2012, 08:01 AM
Originally Posted by IceBlue8 View Post
I had a word with A4 Audi and they don't know which one was done, but Andy says you should be able to tell as the repaired one will have new yellow wiring.
But apparently they're having trouble with repaired/replaced sensors failing again as the water still runs down the wiring into the sensor. Current methodology is to use a inner tube to cover the wiring from top to bottom!
Thanks for finding that out Jim, it saves me a call this morning. I do remember one of the connectors having yellow wires.
Its hard to believe but the wiring is totally unprotected going into the connector and will just drain water into the connector. I will look at some similar method of protection.
